wheel sizes
- Thread starter lali
944 man
195-65-15 is a Porsche approved size (although it was for later cars), but four similar wheels should always carry four similar sizes. 195 fronts and 215 rears isnt an approved fitment and itll upset the cars handling. What wheels do you have?
http://i787.photobucket.com/albums/yy158/A9XXC/IMGP0706.jpg
]Mike
944 man
The tyres are a major improvement over the 215/55 Goodyears that were fitted and a couple of older tyres I tried. However I'm no expert and my car still needs the alignment sorting!
Mike
944 man
I removed a comment Id made about 195s in my first post - which said that they were crap... This opinion was based on a 2.7 which I bought last year, which seemed to drive poorly on 195s. On reflection this could be a combinaton of my moving from a car with 235 fronts, to the 195s on a car which had completely different geo. settings. It felt very light at the front and almost as though it wanted to 'fall' into corners. Casting my mind back a little further I bought a 944 from an OPC on which theyd fitted 4x new Continental 195s, and that drove quite well.
205s certainly provide enough 'tyre', and they handle 280+ bhp in my Impreza perfectly well, so if theres more choice in this size then theres no practical reason why you shouldnt fit them. Toyo T1-Rs are available in 15" sizes here. I might consider the 225. Itll look quite wide on the 7" rim, but not as wide as a 235 or 245 on a 7.5" Cup wheel: and this is common on the racers.
Simon
Neil Haughey
Sounds like plenty of toe in.ORIGINAL: 944 man
Simon
It is certainly heavy by modern standards but ok.
Mike
