Wheel spacers
- Thread starter Guest
So I guess they are approved by Porsche (um, as long as they are the Porsche approved ones!)
Not following the Porsche recommendations would be ill-advised.
The spacers must add to the unsprung weight, but I don' t think they weigh that much.
From a safety perspective, I don' t think there is an issue, as long as you make sure the wheels don' t protrude beyond the bodywork (otherwise it is illegal and you need wheel arch extensions).
I know wheel spacers are not as exciting as deleted posts, but I thought there might be a little more interest after I moved the post here!
Kim
Surely our cars have been designed to the ultimate.... any increase in track width would have an adverse effect on the precisely designed handling characteristics????
But then why have I added strut braces front and rear????
Also got an induction kit from them.
After reading lots of stuff I decided to fit a strut brace to the front of my C4, which already has the sports suspension option.
I had searched the web and the exchange rates were extremely favourable, so I bought them from EVO. Unfortunately they sent a rear strut brace. After I contacted them they apologised profusely and as the cost of P&P would have eroded the savings they offered to send the front brace and let me keep the rear at a very generous discount, which I readily accepted. Really nice people to deal with.
How much difference does it all make? As I am a bit reluctant to track my pride and joy and only car and as the local constabulary were reluctant to let me carry out exhaustive testing on the Farnham by-pass, definitive improvements are difficult to measure without comparing lap times around a track. I will say it is very, very stable at high speed, as found out on roads to Le Mans, less affected by the odd bumps, undulations and cross winds, but at low speed how can you say it is ' better' on our poor English roads. Yes the ride is a little harsher. Front fits no problem, rear fouls the interior shelf carpet a fraction but after a marginal trim of the foam lining in a couple of places you wouldn' t notice.
The induction kit? Sounds wonderful and initially feels like a rocket has been fitted. After the euphoria wore off I did notice that under hard acceleration there is a bit of a lag at about 4500-5000rpm as it feels like the air cannot get in quick enough and it seems to suffer from a slight water-hammer type effect, if you are familiar with this phenomena. Certainly wouldn' t take it off though!
If you do decide to get one from them just remember to factor in any dollar saving with the import duty you will get charged in the UK.
Hope this is of interest. Oh, and don' t forget to tell your insurer so they have an excuse to take another 50 quid off you.
I have also fitted an induction Kit, which has to be said is a mod that I also would not take off either.
How did your engine adjust? ours seemed to take about 100-150 miles slowly getting deeper and louder until the full deep roar between 4500-7000 RPM was acheived. Fantastic!!!!
Fired her up, not a lot of difference to the tickover, just a little ' lumpy' ....
Drove to the corner nice and gently then flattened the loud pedal and wheeeeehooooo!
Didn' t really notice the ' pooter adjusting as it only had to cope with ' throttle wide open, bung in loadsa petrol and make a noise like a bansheeeeeeeeeeee'
Very difficult to drive gently now as I just want to hear that roar!!!![
The idea is to get as much air into the engine as possible, as quickly as possible, (making as much noise as possible(comment from my wife!)), you remove your standard stock air filter and possibly some of your ducting, and fit a washable high air flow cone filter instead, this takes about 15-20mins, with the right kit and will cost between £150 and £350 depending on make.
Ours came from Design 911 Europorsche 0208 900 0900
Airetek £295 +vat
My advice it check the websites for best current price.
Everyone I have talked to who has done the conversion would never go back!!!!!!!!!!!!!
Can you explain what is in the Induction kit?
and where to get it?
check the link on my previous posting dated 18/7/03 re Evolution Motor Sport - good info!!
As the website pictures show, my installation is an open design in the engine compartment although the words seem to indicate they have taken on board comments such as the ones you have heard.
The dyno testing shows an increase in power and I would assume that was measured on a rolling road, probably the worst situation for engine heat effect.
How effective is the OEM fresh air duct I wonder??
It does not feel as if there is a loss of power - quite the opposite but only some properly conducted road testing would prove or disprove any power gain.
For £230 odd quid this is quite a cheap mod for a porsche. They claim if you combine this upgrade with a GIAC Computer upgrade will get you 25+BHP increase....
oo er missus.....
All I do know is that the kit I fitted did incorporate the bottom portion of OEM airbox with an aluminum shield to utilize some fresh air from the existing duct, but I do have to say, gaining another 8-13BHP (as claimed by the manufaturer), is not really the point of the mod, its the SOUND over 4000rpm that is worth the money.
I can say however, I now have quicker throttle response and acceleration than before the mod, so you will have to draw your own conclusions?....
