colinbythesea
Had spacers on my 944, factory fit I think. They just go between the wheel and hub so take of the wheel and bolt it on with the spacer in the way. My question would be why wheel spacers? I stand to be corrected on this but unless you compensate for the extra 6mm with wheels with a different offset your suspension angles will be altered affecting handling. You might need a full wheel alignment after fitting. Also putting the wheels further out will strain the bearings a bit more, not sure how significant this is on Boxsters.
