Wheels Question.
- Thread starter dann944
944 man
I cant see any good reason to fit 19" wheels ( deleted stupid 19" wheels there btw). The cars handle best on 16" wheels and trying to bling-up a 1980s car is rather pointless, surely?
Simon
ORIGINAL: 944 man
According to Porsche you shouldnt fit 18" wheels and you should only run 17"s after replacing the castor mounts with 968 parts.
Simon
Idotic answer.
If you dont have anything positive to say don't say anything at all.
Plenty of people have fitted 19's it all depends on ET, width and tyre size.
pauljmcnulty
Idotic answer.
I don't believe I've ever seen 19"s on a 944? 18"s tend to cause handling problems as Simon said. I also agree that 15-16" are what the car was designed and engineered to run on, 17" with care can be ok. I can't imagine insurers would be happy with 19" as it's so far outside Porsche's recommendations.
A lux would also need plenty of adjustment to the wheelarches for anything over 17" anyway, as they're not rolled as on the turbos.
As I agree with Simon I'm happy to be classed as "idotic" as well. [8|]
I myself would recommend the standard 16's as well but theres some people on this site who would buy their coolant from porsche never mind replacing castor mounts to run 17's!!!!
mik_ok
Good luck finding a suitable tyre for a 19" wheel - you can get a 265/30/19 which comes pretty close in terms of gearing, but you really want something like a 295/25/19.... which only appear to exist in the land of theory at the moment.
Hilux
Its all about the tyre size, and as for recommendations and handling everyone isnt going to be hammering their 944 round the track so putting 19's with the a slight stretch on the tyres isnt going to be the end of the world.
With the greatest respect (and particularly after you shouted down 944man) it isnt as simple as simply throwing on some bigger wheels.
The original suspension was designed to have a certain amount of compliance via the control arm bushes, the top mount/bearing, the damper and spring rates and in particular the tyres (where sidewall compliance helped keep the maximum tread area on the tarmac)
To put 3" bigger wheels with non compliant side walls will upset the damping rates, stress the bushes and together with the now mismatched damping will make the wheel `hop` under poor road conditions, tramline and have dangerously indifferent grip on rough roads in fast corners.
Modern multilink negative geometry suspension ( in a lot of cases with active suspension in one form or another) will allow and adapt for modern wheel and tyre combinations but 20 year old engineering will not (unless you re-engineer it properly)
You therefore need (should) reconsider the compliance in the suspension which is exactly why Porsche recommend the max size of wheel as 17" and recommend that 968 castor mounts are fitted or the `squirm` applied by non side wall compliant tyres makes the car tramline as the contact area is so stiff it twists the bushes!
944 man
ORIGINAL: petem
ORIGINAL: 944 man
Simon
Idotic answer.
Guest of the club with 18 posts..... Pete you are rude and ignorant. Yours strikes me as the only idiotic post on this thread so far. If you want to conduct yourself in this way then I suggest that you leave and try your luck on PistonHeads.
As reading/thinking doesnt appear to be your strongest suit, I have enboldened the 'positive' (and knowledgeable / factually correct) parts of my reply.
sawood12
pauljmcnulty
ORIGINAL: petem
I read quite clearly what you had posted, you critised the guy for even thinking about 19's, there was no need for that - this sort of patronising post is what I find idiotic.
Allowing for Simon's slightly "blunt" answer, he had a very good point. You mentioned that
, I assume you meant 19" not 19 feet [Plenty of people have fitted 19's
Peter Empson
ORIGINAL: pauly
I think 18 inch wheels have gained TUV approval, I like the look of them on my car but it's asking a lot of the standard suspension to control a heavier wheel/tyre, if the KW's I'm fitting don't work properly with the 18's I will consider changing to 17's.
The 968 Turbo S had 18" Speedlines (8" and 10") so the factory considered them ok (admittedly I'll bet marketing had a say in their size, but they do look good). I wonder how the suspension differed on these (I'm guessing just different springs and valving but if anyone has more info I'd love to hear it).
944 man
944 man
ORIGINAL: Peter Empson
The 968 Turbo S wasnt a full production car remember? They couldnt sell them: it was too late, way too dear and the world was in recession.
944's were designed based on the tyre technology available at the time. 968's were designed with later tyre technology and used 17" rims. However, Porsche sent out a directive to its dealers not to fit 17" wheels on 944's unless they changed a component within the suspension for the later one (the caster mount). This demonstrates, without question, that there is an issue in using different wheel diameters over and above that recommended by the manufacturer.
I would further suggest that if you changed your wheels and had a crash as a result of a failed caster mount your insurer may well use the Porsche directive as a case for not paying.
Why go for bigger wheels any way? On an billiard smooth track stiff tyres may provide better control but only if the rest of the car is able to work within the parameters of the tyres. Otherwise the reduced compliance in the tyres will introduce further, potentially damaging, twisting forces further down the chain. The grip may be greater but the breakaway is going to be far more abrupt.
The only other, or perhaps main, advantage is to allow the fitment of larger brakes. This being the case IMHO little looks more ridiculous then massive diameter wheels wrapped around puny brakes.
The tyre wall is a significant element of the cars suspension. If you reduce the side wall height you reduce the tyres ability to absorb bumps and changes in road surface. Old fashioned suspension doesn't work well enough to counteract this. The ride will become choppier, the car will tramline and driving at speed on anything other than a smooth road will see the car fighting you constantly. I had a road registered racing car and driving on the road was not fun as the car would endeavour to throw you into every ditch or hedge even when driving straight - on a track it was sublime.
So in summary, if you want to fit bigger wheels please go ahead. It will impress 12 year olds but but wont gain you credabillity with those who know.
pauljmcnulty
What wheels you running, John? [
Sorry. [
Peter Empson
ORIGINAL: 944 man
Your point being??? Porsche released the car to journalists and potential customers with 18" wheels on it, the few that did sell had 18" wheels on them, so my point is that they themselves sold a 944 derivative with wheels that were larger than the factory once recommended. To me this suggests they must have considered them both safe and acceptible in terms of performance with whatever changes they made. The fact that the car was a flop as it was at the wrong price at the wrong time is surely neither here nor there?
