Wheels - will these fit?
- Thread starter RSGulp
Dave Wilkinson
ORIGINAL: 964RS_DAB
I think 9" fronts are too wide, 10" rears are OK, but I believe the correct offset for a narrow body 964 is ET61.
As a guide - Speedline 18" Cup 1 split rims are front 8" ET52 and rear 10" ET61
David
The Speedlines with ET61 on the 10" rears are designed for the wide body trailing arm as fitted to the 3.6 Turbo. The ET61 offset is too much without a spacer for the narrow body - the wheels will foul the oil pipe in the right rear. The standard wheels on the narrow body cars are ET55 (actually the C2/C4 had ET52.3 on the 16" D90s) but the wider rim necessitates a smaller ET to move the inner rim surface away from the oil pipe. Most aftermarket 10J rears designed for the narrow body are ET47. The BBS 10J wheel with an ET50 is OK with a 265/35 tyre.
Dave
jason
ORIGINAL: RSGulp
Talking about polishing and garages... how are the shiny flooring, shiny walls and shiny upside-down framed posters coming along at the Graham household? [][]
The flooring is lifting in places, the walls are the same and the poster is still upside down!!!
But its again full of kids and wives rubbish once more.....you'll learn about this soon....[]
Hacki
ORIGINAL: RSGulp
So, we've established the rears will fit with a narrower 265/35 tyre. Are the 9" fronts going to be a problem - or should I hold out for a set of 8"s or 8.5"s?
Rich,
even if the 9" fronts fit, you won´t like the car´s handling with these wide front wheels.
The only reason for wide front wheels is to change the driving to polishing ratio from 10%/90% to 0%/100%.[]
Rgds,
Hacki
P.S: What´s it like to be verheiratet?
ORIGINAL: Hacki
ORIGINAL: RSGulp
Rich,
Rgds,
Hacki
Hacki ---you got me [][][][]
verheiratet
ORIGINAL: Hacki
Looked glucklich at the polo!! []
ORIGINAL: Hacki
Verheiratetes Leben ist gut, das Auto ist noch in meinem Namen!
Hacki
ORIGINAL: RSGulp
ORIGINAL: Hacki
Lucky you!
Congrats again![]
