sawood12
I'm starting to think about those maintenance jobs that I should do as soon as the weather starts to improve and have read up on the workshop manuals but I've still got a few queries:-
Clutch Slave Cyliner - seems like a simple job. Is it necessary to remove the starter motor and fully drain the clutch fluid?
Gearbox Oil - Maintenance manual suggest you should drain the oil while it is warm. Is this necessary? And is Swepco all it's made up to be or am I better off with common garden fully synthetic oil at the required grade?
Rear shocks - Potentially a very daft question but here goes - is there a bump stop that the trailing arm rests on when the side of the car is jacked up to prevent the trailing arm springing back when the shock absorber is removed? I'd hate to remove the shocker and the trailing arm to spring back.
Cheers.
Cheers.
