Black Beauty
Attached is a photo of the underside of the badge panel from my 84 Lux, sans bumper, which needs to be removed so that I can re-attach the badge and also so that I can get it re-sprayed.
My question is simply where do I cut? Some may re-call that the early 944 badge panels are bolted and spot welded on, I suppose just in case the bolts disintegrated into dust, so unlike you lucky buggers with the earlier models, its not simply just a case of undoing a few awkward bolts.
Any pointers would be gratefully received
Spence
Spence
