where is a good place to buy
- Thread starter Guest
912UK
Any way the shocks I got a pair of Koni Adjustables for the rear and monro' s for the front from a mate in the trade the discs I did on a lathe as I used to be a machinest.. Only to true them up and take off the worn edge.
Need to get some rears at some time as they are very close to under size Miggs sit down when you get a price for the rears on the 69.
Mark
Still on date 3 working on no 4 [&o]
Sorry I was a bit abrupt there, the pub has just put on some 5.7% IPA.... Wey-hey..
Discs can be skimmed down to the Porsche spec min thickness, I will check that in the morning.
Dampers: no option but to fit new inserts (front) items (rear)
Caliper kits from various sorces, Mark (911UK) has the tool to get the old pistons out.
912UK
Front disc and rear Poss Design 911 or Germany
Rear shocks German and sweedish and the front if not euro car parts
Front and rear pads I got from my local car shack Also the pad pins as well
Caliper repair kits / Pipes Rodger Bray (if you want to have a laugh phone KK then revel in the money you saved [])
Mark
my cents worth from what I did[]
I assume your discs are solid and not ventilated? Solids £45.60 each
Rears discs £40 each
What make of struts are fittrd to the front? Koni or Boge?
rear shocks £96.25 each
front pads £17.60
rear pads about £12 set
calliper repair kits £8.00 & £10
912UK
Mark [][][]
the 69 disc if you are unlucky to have them on your car are £110+ EACH!!!!!!!! they only made them for a couple of years [&:][&:][&:]
My shocks were £40+vat each boge
912UK
Miggs if we both do have 69 disc' s lets see if we can sort out a deal with some one will have to be later as I need to get money togeather for a few things at the mo.(bl*&^Y women )
Mark
912UK
Yes I have the tool for the Calipers you will need a porta pack to pump out the calipers Alex as it at the mo .. if you need it give him a call and send him a Jiffy SAE then send it back to me or hang on to it untill AJP.
All the best
Mark
looking forward to the camping weekend end of month just got 24 Grolsch ready for it £12 from Tesco' s only trouble is I am started on them already [&:][&:][&:][&:]
