Sandspider
Well, like the title says, since I replaced my oil filter and oil at the end of last year (1986 Lux), oil consumption has increased dramatically. I wasn't measuring it carefully, but I have done so recently and it's 1l oil per 200 - 300 miles! It started when I used fully synth 10W40 rather than semi synth, so I'm topping up now with semi synth, but so far it doesn't seem to have helped. (I've probably topped up around 4l since the initial oil change)
The baffling thing is, I can't figure out where the oil is going. It's not leaking out when the car is startionary - the block and my drive are dry as a bone. It's not burning - my exhaust is clear, smells sweet(ish) and is filled with flapping butterflies, not black smoke. I assumed it might perhaps be leaking out under high pressure acceleration, or when hot... But just now I topped up the oil to a smidgen below the max mark on the dipstick, and ran the car on my drive for 5 or 10 minutes with a bit of revving from time to time to simulate driving. (Fan came on twice, and went off again each time) Not a drop of oil emerged from anywhere, but the mark was a smidge lower on the dipstick when everything had cooled down and dripped back into the sump. (I know, the dipstick is not totally accurate etc., but oil is definitely going somewhere). At cold idle oil pressure is 5 bar. Under acceleration, 5 bar again. At warm idle usually 4.5 - 5 bar, but can decrease slightly towards 4 bar as my oil level decreases. Baffled! [&:]
Does anyone have any thoughts / suggestions as to where my oil is going, or what I should do next to find out?
Many thanks in advance...
Giles
Giles
