peanut
My S2 is not starting and I am pretty sure that it is the fuel pump that's at fault.
Pump Fuse is ok when I replace the fuse with the ignition on I cannot hear a relay or the pump ? It did try to catch when I turned it over this morning on full throttle but died immediately just like a fuel shortage.
I thought I'd give the pump a tap but can't see it. Exactly where is it near the tank.? which side and before or behind the rear wheel?
will I need a ramp or axle stands to get at it ?
