where to buy water pump and cam and balance belt kit
- Thread starter swainey
chrisg
I'm not sure about where/who to get a waterpump from - depending on your timescales and the 'type' you've already got fitted to your car, you could consider a re-conditioned pump - there was a thread on here a few months ago about this. IMSR it was waylander that was arranging this.
Regarding cam/balance belt kits, you could make up your own 'kit' of pulleys and belts from GSF/Eurocarparts etc. However, having recently done both these jobs myself I found it quicker,easier and of no cost saving to go directly to Frazerpart for the complete kit - I'm not sure who it was I spoke to on the phone but the chap was very helpful and I got quick delivery.
If you're doing the job yourself you'll need a few tools, there's a new company supplying them at very reasonable cost:
http://plus4e.com/2016/01/21/plus4e-venture-into-porsche-tooling/ they can also supply the pin spanner for holding the balance shaft pulleys and the drift you'll need to replace the front crankshaft oil seal if you need to replace that too. I understand from speaking to the main man there they're looking into other tools such as a puller for the clutch fork shaft, flywheel lock etc.
I've now done the job a couple of times - I'm no expert on it but always happy to help and provide advice - chrisgrahame@yahoo.co.uk or 07540 193874
Yours
Chris
As ever it's worth checking prices with your local OPC, but spares from them seem to be getting pricey these days!
Waylander
EP services
about £90 lifetime warranty
http://www.ep-services.co.uk/
Speak to Paul, the pumps have to have metal impellors that are not corroded away.
I have one on my 968
Chrishazle
If you want to go this route then I have an old S2 pump which I have squirrelled away for such an eventuality. If you wanted an exchange item to send them then I'd be happy to help.Waylander said:Refurbs
EP services
Waylander
zcacogp said:If you want to go this route then I have an old S2 pump which I have squirrelled away for such an eventuality. If you wanted an exchange item to send them then I'd be happy to help.Waylander said:Refurbs
EP services
the more we all send him the more he will have on the shelf for same day exchange.
I have 3 here to go as well, a job for next week
g944s2
swainey said:yeah seen the rosepassion price.... its not bad anybody used them ...
I used them for the water pump, timing kit etc. Very good at answering questions and all parts were excellent quality arriving in a couple of days.
swainey
shame... i need the 2.5 water pumpnick_968 said:2.7 & 3.0 blocks use the water pump with the larger impellor. 2.5 blocks use the smaller one. I have a brand new Laso pump (2.7 & 3.0 block size) for sale that I did not end up using but it is the larger type which is not the one you need unless you want to modify the casting on your block so the larger impellor does not rub.
