Thanks for your input guys, to change the suspension on the rear of a c2 to rs spec requires three things essentially from a control arm point of view. The lower "A" arm has a harder bushing in its inner pivot point. The kinematic toe link (rear/upper) also has a harder bush on it's inner pivot, and the subframe mounts are also of a harder rubber composition. The subframe has longer camber eccentrics to reduce the rear camber when the car is set to low ride heights( most c2 lowered to rs height cannot reduce the camber to the rs spec, usually ending up with -2 degrees as a minimum attainable)
I was thinking about changing the two links that have harder bushes to either shore 85 rs spec rubber or solid "rose joints". If i leave the subframe mounts soft then i might get away with the monoballs????
Christian
