This is an example of what I was thinking re the pre-muff:
"very little can be gained by disconnecting stuff from a motor
from how Porsche made it. BUT, that said, what else are you going to do to
the engine? The engine is designed to like a bit of back pressure - helps
with mid rev torque with valve over lap. Not enough back pressure and a
goodly amount of intake charge remains out of reach when the piston starts
its down stroke and the exhaust valve shuts too soon. However, if you
richen up the mixture, this will (read - may) be negated. However, the
sound will be a nice throaty sound."
So without the right mapping, a "sports" exhaust is often buying you no more than sound and perhaps less torque into the bargain. This lack of mid range torque makes it feel like there is more top end horsepower. Sad but true.
