Whine from speakers
- Thread starter Alexw
Peter Empson
Are you using a seperate amplifier or is everything in the headunit?
If you have a power amplifier just try dropping its input gain, this might be sufficient on its own. Also make sure the cable between head unit and amplifier are short and of good quality (loops of spare cable are a bad idea, for example). Adding ferrites and possibly an isolating transformer are other options.
If you've just got a self contained head unit then I suspect it's a bit more tricky. I'd try to hunt out if there's something amiss in the car first, a poor ground or similar (either at the radio end or related to the engine electronics).
Other than that I'd check to see if it just does it on the radio or on CD as well, you could try disconnecting the aerial input as it's a potential source for interference, especially as there's an aerial amplifier on these cars (it could possibly even cause noise on the CD input if it was strong enough).
There are so many sources of noise that I suspect it might be a bit tricky to resolve quickly, but if you can give us some more information it will help (stereo model number and so on).
