Landroverstormer
I had a small leak from the rear diff and a slight whine. A local mechanic changed the diff oil and added some sort of addative to relax the seal to hopefully stop the leak. Good news is that the leak has gone, however the whine seems to be a little worse (could be my imagination?).
What I wanted to ask was whether this is a common proplem on 944's which is what I'm led to believe. I've been told to turn the radio up and not to worry about it, however I don't want the thing to 'let go' at high speed as it would probably be a little unnearving to say the least.
The noise is there on overrun in a high gear, but then as you apply load it goes momentarily but then as the load takes up the slack it comes back. So in a nutshell it's there under load and under engine braking but not in between. I'm thinking that it could be an input bearing or something similar as opposed to the diff itself?
I just wondered what you guys thought it could be and if it's anything worth getting worried about. My other concern is whether the mechanic has put the correct diff oil in which could have caused the increase in volume.
Any advice would be great!
James [8|]
James [8|]
