Whistling noise from engine
- Thread starter cherus123
It's not an expensive fix - and it's covered under warranty. Do get it fixed sooner rather than later or very suddenly the engine could overheat, you'd lose power steering and the battery will die in quick succession.
There goes another rib.........[]ORIGINAL: carreraboy
Maybe it's telling you it's ready[]
ORIGINAL: cherus123
Hi,
When i start my engine in the morning it makes a whistling noise. After driving it for about 5 minutes the noise goes.
Anybody have an idea of what it could be.
Try a touch of talcum powder on the V belt - no really it's not a joke [].
If the whine stops temporarily then you know its a faulty belt.
Regards,
Clive
ORIGINAL: cherus123
Hi,
Alternator at a guess - they normally whine slightly under load, or a lot moe if the bearings are on the way out (a not uncommon fault).
