White Noise!
- Thread starter Guest
ORIGINAL: jimbers45
Does anyone know where I can get a documented static noise test done........last thing I think any of us newbies want is to turn up to a booked trackday with our pride and joy and end up disappointed and out of pocket?
James
when doing static test be very nice & chatty to the marshal doing the testing - they will often allow a bit of leeway as a 911 with the engine at the back will be louder than a front engined car which they are often aware of. I was also told to put the clutch in when revving the engine to stop the additional rattling and grinding you get from the RS when not in gear - dunno if it makes too much difference. some of the less ethical people I know may also not rev the engine as high as requested [] so keeping noise down further...
Alternatively get a mate to join you in his company car - you can always take that on track if the RS fails...
I've got a 'Tudor mortar' that bolts on instead of the tailpipe from Merlin at Combe, worth 2-4dbs. Anybody welcome to try this, as surplus to needs since I've fitted the C2 back box, now about 100db...
The noise test will change depending on angle of mic, ambient conditions, air pressure and temp and cloudbase, also proximity of buildings and road surface.
I got around this at Bedford once by them measuring the car on the trailer, with the exhuast some 2' above ground level!!
"How are cars tested for noise and will my car pass the noise tests?
The vast majority of tracks in the UK have noise limits imposed on them by their local councils. These limits vary from track to track and some tracks have several different limits. The limit for each event is displayed in the event detail boxes. They are generally measured in the same way. A noise meter is placed at a 45 degree angle to the exhaust outlet and 50cm away *. The car is then held at 3/4 of its maximum rev limit and the highest reading recorded is the cars recorded noise output for the day. If a car is over the official limit, the car will not be allowed onto the circuit. easyTRACK will have no part in this process or a say in its outcome. If you do not know what the noise output of your car is, as a general guide most standard road cars will record lower than 98db (the strictest enforced at any of the venues used by us), indeed many sports exhaust systems will also, but may reach 102-3db. However, if in doubt get the car tested prior to booking an event, you are welcome to visit any event of ours for a test. If your car is too loud for a particular track, fear not, we can hire you extra silencing equipment (subject to availability). "
*75cm at some tracks
