Stevenash56
Hi all I hope you can help with some answers 986 3.2s recently mot,d with no emmisision issues what so ever never had issues with white smoke on start up before. Drove about 50-80 miles .Now on start up huge plumes of white smoke and I mean it hangs for 1 to 2 minutes in the air .Then on driving goes away on start up from even leaving it only 1 minute smokes again then goes away .It's not the normal small puff as is known on boxster .last trip engine became lumpy as in mis firing and white smoke as if the engine had gone then on acceleration disappeared as did the misfire. I hope you may have some avenues I could go down . I've changed the MAF no change .Engine light doesn't come on. Was looking at changing coil packs Lambda Sensor's to see if this helped
Thanks in advance
Steve
Thanks in advance
Steve
