Hi
I was wondering if I someone could give me a bit of advise.
I have a 2000 Boxster 3.2S, when I start the car from cold a get a puff of white smoke, this only lasts a couple of seconds and then all is normal. This only happens the first time I start it, if I leave it parked all day then satrt it up - no smoke.
I have owned the car for about 6 months now and it has always done it, the car uses no oil.Is has only done 48000 miles, has OPC history to 42000 and specialist history since then.
I recently had my local OPC replace the all the spark plug tubes as they noticed it was leaking a bit of oil but this has made no differance. The problem became more noticable following its last service, this could have something to do with the oil being thinner.
I rang my local specialist service centre and they told me it was quite common for this to happen, explaining that the layout of the flat 6 meant that oil could collect and not run back to the sump and any oil that collect would burn off when starting the car.
Has only one else had any similar experiences. Please let me know so I know if I need to have investigated.
