Why 8v turbos?
- Thread starter Alexw
951Torqing
(Although I believe I saw some where of a 16valve converted Turbo but cant remember where)
Clive
8 valve Turbo and extremely contented with just the 8.
Actually the 924GTP (944 prototype) that ran at LeMans used a 16v turbocharged 944 engine but given the makrket the 944t was aimed at (ie performing below the 911 turbo) I guess they didn't go all-out with the spec.
4v heads do two main things - they allow more flow (larger total valve area), and allow the engine to rev higher (less valve inertia in two small valves vs one big one). Since forced induction gives more charge with a 2v head than an NA 4v head and the big pistons are probably more of a rev-limiting factor than the valve inertia I guess Porsche didn't feel the extra complexity was needed. Forced induction has come a long way in the past 20 years []
Diver944
944 and 968 were still the budget model for Porsche at the time so there would be no point sticking a 16v head on and making mre power than the flagship model. There have been a few 3.0L 16v turbo conversion in the US and Patrick in Oz is working on one as well as SimonP over here who built my 3.2 8v
