It's top-down weather again, hurrah!! Unfortunately my first attempt at dropping the top this year took some of the smile from my face. I've got the Wilhemy unit installed and it should allow me to drop the top in a single button press but this no longer seems to be working properly. When I go for the single button press operation the process stops after the rear cover gets raised a few inches; same situation for both up and down. This seems to be the point which must be reached before the car has decided which direction the roof is going in; when I put the original unit back in this seems to be the point before which you can't reverse what you're doing. Once it reaches this point then you can reverse the direction (or maybe my mechanism is acting up - I've had the motor replaced in the past because the sensors detecting direction of travel were buggered).
Anyway, has anyone had similar problems with the Wilhemy unit? or can anyone shed some light on why it stops at this particular point - I have been able to drop the top with the single button press operation on the 2nd attempt after it stops but I have to keep my finger on the button completely to get the hood to come back up.
