will a 3.6 1990 engine fit straight into a 1987 3.2
- Thread starter Guest
ORIGINAL: 911 2
if changine my 3.2 carrera for a 3.6 carera engine will the engine fit straight into my 1987 3.2 and will all the ecu loom all connect up and work or is thee more to this also will all the alternator starter etc fit from the 3.2 to the 3.6
Call Gordon Hayward at Hayward & Scott as he did this conversion on his 3.2 Supersport Cabrio 01268-727256
I am sure he will advise you of the pro's and con's []
911SSC
I think from what we get in the workshop that things have moved on a bit and now and you find that the 993 engine is more a common conversion.
You are more than welcome to ring and have a chat.01268 727256.
Ian
Derek
Ex Club Member
Yes it was! Good memory! I said in the article that I was going to supercharge it at some point and Phil Raby called me a bit of a mentalist.
I've now done just that - and still with the 915 'box. The look on 996 owners' faces as they see a humble 911SC pulling away from them!!! Priceless!
