will a 996 turbo engine fit into a boxster?
- Thread starter RonnieG
But you've got a bit of a job on your hands!
Steve Brookes
Moderator
Would be interesting to know which are which.
Steve Brookes
Moderator
ORIGINAL: Peter Bull
Maybe that was down to the different driver abilities. Would be nice to have seen a back to back comparison by the same driver though/
Totally agree with you Peter that the driver factor is always difficult to quantify. My observation was that most of the GT3s were quicker but then again, the RS day attracts a lot of good drivers. If I'm not mistaken, the turbo engined boxster (and I was lead to believe that it was a true 996 turbo transplant) is a friend of Simon at Porshapart. I guess it must still be very much a work in process, otherwise the car no doubt would be much better known by now and would surely have appeared in some Porsche mags.
On a related topic, I know the owner of the 9M supercharged boxster very well. That car went through many transformations (including three engines) but was always a disappointment because the reliability was never there, neither was the real world performance.
For me, the boxster is at its best as it left the factory and the latest Spyder is the best of them all [
DivineE
ORIGINAL: Steve Brookes
I believe that is because they try to do it without changing the factory pistons. I don't know for sure but I've heard that somewhere and would make sense if that is true. No reduction in compression ratio would greatly limit the amount of boost the car could run so you'd get pretty small gains. No additional taper on the pistons as you would have on factory turbo pistons means hotter pistons, leading to running tighter tollerances and then seizing.
DivineE
ORIGINAL: Laurence Gibbs
I would think there are a few problems to overcome. Principally HEAT the Boxster rear end just isn't designed to cope with it. And where would you put the intercooler? Other problems may occur when trying to get all the electrics talking to each other. I think my dim and distant memory remembers something about each unit in the car being coded. So a new Turbo DME might not work without recoding? Then as Mark suggests gearbox matching might prove a pain. Nothing is impossible, but some things may as well be[]
GT3 Engine it is then.
