Will the wrong fuel damage anything ?
- Thread starter Guest
ORIGINAL: slim_boy_fat
Very funny..
Come on i had to ask, the handbook says 95ron
ORIGINAL: 944 S2
Very funny..
Take that as a minimum, i doubt you would notice any difference. But the opticon does have better cleaning properties according to someone whose name i forget. [
p.s. did you know there is someone on the forum with the name 944s2, lower case 's'. Oh he's not going to be happy, not only that but he's from the briggs!!!!!!
YES i did notice after i registered, never mind i'm sure he isn't as bothered sa you are [
I actually thought it was Dougie at first. You west coasters aren't very original, are you (says me using my real name).
I find after a few tanks my S2 runs noticeably better on Optimax, although I thought Esso Supreme or whatever was even better.
ORIGINAL: Fen
Have you ever used a valve cleaner or injector cleaner on your cars fen ?
I guess a clean may a be fair bit of what's making the difference but I swear I could tell straight away if somebody filled it up with 95RON so now it is clean the extra bang is noticeable too.
sawood12
I've heard it does give you better fuel economy also but not sure if the economics against the 5p/ltr extra cost would work out.
Cheers.
Diver944
ORIGINAL: sawood12
So I take it from this email thread so far that some of you think that 97/98 RON fuel is not worth the money
I would say it's not worth it for a standard car, but it is in a modified one.
My S2 does a little more mileage per tank with Optimax, but it costs 8% more so it's not worth it IMHO. Modified cars can make extra use of the higher RON value and will therefore be able to extract more power from it which is why I use it all the time in the Turbo [
chrisr
It DOES NOT mean the fuel will produce more power.
Its does as Paul says allow the engine to be tuned to produce more power without the engine knocking. Unless the engine can adapt via the ECU (or has a chip that has ben adapted) to the higher octane fuel it will not make any more power.
Optimax has other apparent properties which might make it worth while using. Primarily it is supposed to clean the engine very efficiently. There are magazine tests floating about which show this.
I use Optimax in mine but again its in a higher state of tune that standard which i think warrants all the help it can get.
Don't forget that a higher octane fuel only prevents detonation/pre ignition or knock (whatever you want to call it)
HIGHER STATE OF TUNE - LOLsssss
Never heard you call it that before [
sawood12
And presumably will be of aid when/if I decide to chip it.
