Will these fit ?
I have some 17" Cup 1 wheels which apparently fit an early 944.
The sizes/offsets are:
FRONTS - 7 1/2 J X 17H2 ET23
REARS - 9 J X 17H2 ET15
Has anybody fitted these? Can anybody confirm if they will fit?
many thanks in advance
Yes those offsets are for the early pre ABS cars. They will not fit an S2, Turbo or 87 onwards Lux as the wheels will stick out an extra 30mm and foul the arches
They will fit straight onto a non ABS 944 but I'm not sure about your C2 if that is where you want to use them.
The offset is cast into genuine Porsche wheels by the valve if you need to check.
