944 man
Theyll fit onto the hubs, but the offset will be wrong. Your car has a nominal 23mm offset and these wheel have a nominal 52mm offset. In order for them to fit properly youll need 30mm spacers all around. You can get by by using the longer studs and factory spacers from an early 944 on the front, so youll only need to buy expensive spacers for the rear. When you take the original wheels off the factory spacers will almost certainly have stuck to the wheel face. Most people dont realise until they wind through the ends of the alloy nuts... Simon
