WIND MIRRORS !!!
- Thread starter pal944
My teardrops are being a nightmare: First I had them painted with the bases on, then realised they were for a LHD car. I had a pair of RHD 911 bases in the garage so I got them painted and then struggled with my indie to put them together. After using them I realised that being LHD the passenger glass was flat rather than convex and didn't therefore have enough field of view. I got a convex glass from the OPC on Saturday and fitted it in the afternoon. When I finished I was putting the mirror body back to the right place and the sodding thing popped apart again [
If you really want to take them apart you need to push the hex socket headed "bolt" you can see from the bottom of the base against a spring and turn it about 1/4 turn. That's relatively easy (especially if you don't care about the paint). Getting it back together again is reversal of that and it's a royal pain.
If one is already apart then you can probably see how the base is held on - you should have the bolt thing with a spring round it. You push it up through the base into the top part and the 3 dogs at the top locate with depressions inside the top.
random hero
ORIGINAL: random hero
The base will have 2 locating tabs and an allen bolt which goes through the top of the base into a captive nut in the door. The teardrop mirrors fit all the existing mounts from the flag style mirrors
Yep, that sounds right. I remember looking at the hook on the 911 ones and thinking it was odd. The hook is instead of the captive nut.
jez_anderson
Now afterall that I am starting to worry that the electrics might be different between a LHD and a RHD? The cables / connectors coming out of the mirror bases are different ie the one sticking out of the left hand mirror looks different to the one sticking out of the right hand mirror. Is the cabling "handed" as well? Will the fit ok? please say yes....
What you will have is a passenger side glass that is flat giving a narrow angle of view and actual size reflection and a driver's side convex glass giving a wider angle of view and a smaller than true reflection. Personally I hate that combo and have replaced the glasses in my 964 ones to get them the correct way round for RHD.
