Window adjustment
- Thread starter Guest
Once the door card is off you need to identify the two adjusting bolts, the front one located nearer the door hinge governs the up and down limits and the rear bolt nearer the lock end of the door governs parallility of the top edge of the window.
You can identify the bolts as they occupy slotted sections in th door steel pressing. The front bolt is loosened and moved forward to raise window height and moved rearwards to lower window height. Remember to mark positions before you start for reference points.
Reassembly is reversal of removal but take your time with the window regulator switch and its' rubber shroud as things are quite tight here.
Hope this helps, sorry no pics to guide.
Ian.
1987 3.2 Targa
Audi A6 1.8T.SE.
