Hi,
have found a weird electrical gremlin:
Passenger window will lower / raise fine from either passenger door or driver's door when ignition off[
but: with ignition on - then the pasenger window will not lower[
] from either switch,
Last weird symptom - but if you had lowered it before turning on the ignotion, - and then turned the ignition on - it will allow you to raise it??
The drivers window continues to be fine.
Any thoughts on what is causing this?
Many thanks.
T[&:]
Many thanks.
T[&:]
