Window lowering sounds like loose stones
- Thread starter Guest
I was afraid of that. Had a look at a guide to taking the door card off, and it looked nasty.
I removed my door card yesterday to fix a rattle behind the side airbag cover. Once you know what you're doing it's really only a 10 minute job.
1. Lever the door handle cover off (make sure you pull it away from the door and not up or down)
2. Remove the 2 bolts (using Torx bits), and 1 screw (Phillips - hidden behind the door opener)
3. Unscrew the screw located inside the storage compartment slightly concealed at the top (Phillips).
4. Pull out the door light and undo from the bulb.
5. (For facelift cars) Lever (carefully) the silver airbag cover, and undo the allen bolt within.
Now you just pull the door cover off from the bottom towards you, until each clip has loosened.
Work your way around the door card until the left/right/bottom are now loose.
Then you push the whole door card up from the bottom/sides, as it is now only 'wedged' in place at the window sill.
Job done.
ORIGINAL: sbloxxy
....... I got a good secondhand one - £120 - and fitted it myself.
They are "only" £123.70 inc VAT from an OPC!
sbloxxy
As for the actual job, I also initially thought it looked like a bit of a nightmare - in fact it was very straight forward and probably only took 45 mins or so, start to finish. Once the door card is off, the regulator is held in with four small bolts - two top and two bottom. You disconnect the wiring to the motor and wangle the whole thing out of the aperture in the lower half of the door. The new one goes in the same way - mine came complete with window motor which made it slightly easier. Whatever you do, don't be tempted to strip the regulator - once the cable unwinds, its stuffed. The trickiest bit was working out how the door card is removed.
sbloxxy
