lesworth
My passenger window has stopped working. I did some obvious checks such as swapping switches which made no difference. using one of those screwdriver type testers I'm pretty sure the passenger switch is receiving juice. I know its not the regulator as there is no noise at all. That leads me to believe the motor itself has failed. Assuming that it is receiving power (I'm going to take the door apart to check), is the a quick easy way of testing the motor before going to the expese of buying a new one?
You can probably tell that car electrics are not my stong point...[
