Window motors lubrication?
- Thread starter Guest
Not ever had to work on window motors myself, I suspect the design to be the same as any other motor. In so much as you can successfully lubricate the bearing near the brushes but the bearing at the other end of the armature is usually sealed in the motor housing! Meaning pulling the whole motor apart just to get at the other end! Very tricky. First question tho' is why do you want to lubricate the motor? Is it squecking or making other unsavoury noises?
Please advise.
Good luck
Alex
