JamesBall
My car suddenly developed a very loud rattle from the rear edge of the drivers door so I took the door panel off to find that the metal guide at the rear of the glass within the door was unattached at the bottom and the rubber/felt seal that I assume should sit between the glass and the metal guide was loose inside the bottom of the door.
Is it possible to refit this bit of rubber/felt without taking the window out. I certainly hope so because I have pretty much reached the edge of my comfort zone mechanically already I have tried feeding the bit of trim back up the guide without luck.
Also, what keeps this bit of trim in place? Is it just push fit?
