window scrapers
fgasca
Good night everyone,
I got a new pair the scrapers to replace the old ones in the front windows. Has anyone done that already? It doesn´t look as a dificult task but probably will be once the job is started. Do I need any special tools for that?
Thank you
Fernando
Which scrapper as there are three on the 964 windows.
1) Outside car and visible ..just flip the whole trim off in one ( up wards) and slide off the scrapper and refit ...held on via spring load clips through the top of the door...each clip sealed via little round sponges
2) Inside car visible at the top of the inner door trim ...remove the inner door trim
3) Inside car but hidden under the inside invisible trim .... remove indoor trim and take the glass out
Ian,
Thank you for the answer. They are the outside and visible ones.
By the way, could any let me know which is the best manual for small DIY? The Haynes one?
Thank you
Fernando
Haynes do not do one for the 964 ..so its either the Porsche Offical manual or the web . But a lot is the same as the 911 SS etc ..that I think Hayes do a manual for . FYI the Offical 964 manual asume alot of expericance and does not cover items like door trims ....;-(
