Windscreen Corrosion update
sjevans
On advice received via the forum I approached Porsche through my local OPC.
They have fixed the corrosion under warranty.
Thanks for the advice.
Stephen
They didn't put up a fight at all and were very helpful. Exeter OPC.
However, their approved body shop was "sub-optimal". Cramped, busy and full of all sorts of marques.
They took twice as long as they said, broke my alarm sensor mounting with no replacement, de-wired my neatly routed Snooper and left dirty finger marks all over the place. It is going to take time and hassle to put it right.
Stephen
ORIGINAL: sjevans
Stephen
And places like this manage to stay in business. Sounds like a nightmare from the 1970s.
Is this dreadful outfit paying for the stuff they broke or compensating you in some way?
They also put a door opening dent in the rear wing.
I am awaiting a response to my toxic letter of complaint.
Stephen
I can advise you that when OPC "sorted out" my windscreen/scuttle panel corrosion under warranty they did not put any corrective measures in place. This winter the screen leaks/water still sits under the seals and I have already found signs of corrosion under the seals. THE CAR LIVES IN THE GARAGE !!!
Now it has to go back again.
I washed the car this weekend and for ages afterwards (24 hours) water was seeping out of the seals. I don't like the look of that. While it was with the OPC I had a major service costing £890. The car is running well and I don't mind paying for quality but the experience of their "approved bodyshop" makes me wonder whether all I got was another OPC stamp in the book.
Stephen
If it did nt have it already , they should put Teflon tape around the edges of the body work, cuts out squeaking and any chaffing to paint .....................probably whereever u take them the OPC calls in a screen specialist ....................in the ;ast 3 replacements i ve had on 993, 2 needed redoing ..........................just tell em !!!!!
