Windscreen Scratches
Terry
Anyone know if it is possible to polish light scratches out of the windscreen?
I have only succeded in making it slightly worse so far by using something too abrasive. Any information on what to use and how to go about it would be much appreciated.
Terry
I've got an area of scratches in my passenger window which I'd love to remove. I'd be interested to hear how you get on!
I've got a few scratches on mine as well. Not from the wipers, but up and down as if someone was drying the car with a gritty cloth [:'(]
I didn't find the Zaino Glass cleaner & polish helped much, but I can highly recommmend it for a deep-cleaning of the glass [8D]
You need Jeweler's Rouge (look for suppliers on eBay) and a small high-speed mop. Something like a Dremel is perfect.
ORIGINAL: Robertb
But does that not cause a small distortion in the patch of glass you polish?
You'd have to spend a really long time in one place to do that.
Thanks for all the feedback.
I will give the windsceern scratch polish a go and see if it works. I will let you know how I get on.
Terry
I just caught sight of this thread in passing and it occurred to me that there is a company called Glas-Weld (http://www.glasweld.co.uk/) who not only repair chips and cracks in windscreens but also can polish wiper scores and the like. The chip repairs are usually done free of charge without excess payment under your insurance but I don't know if the scratches can be repaired on the same basis. Got to be worth asking though.
Dave
I tried contacting Glasweld as suggested by Computamedic, I was told they did offer a windscreen polishing service and that a technician would contact me - I am still waiting!
Eventually I decided to order a Windscreen Polishing Kit from ABC Polishing, they can be found at http://abcpolishing.co.uk The kit was £21.50 plus postage. It arrived within 4 days of ordering and comprises an abrasive powder, a polishing powder and 2 polishing mops for an electric drill. It worked pretty well and the end result is good. The scratches that I had were not too deep but there are other kits available for deeper scratches.
Thanks for all the suggestions.
Terry
The side and rear glasses are all zone toughened the front screen is laminated and has had no heat treatment.You may be able to remove very lite scuffs with car cutting compound or basso but be careful not to press too hard.Be very careful to stay away from any cracks or stone bruises on the front screen as added pressure may cause them to move further.Rule of thumb is if you can run your finger nail across the scratch and feel a definate recess in the glass then its probably too late.
A point worth remembering would be to state that you want a factory windscreen when you are getting them replaced.These are usually Securit brand and will be stamped on the bottom centre or left of the screen itself.They fit a whole lot better than the Chinese knock offs that most insurance companys try to have fitted.
ORIGINAL: hastings glazing
Thats a really useful bity of information there - thanks very much
Be careful! I had a scratch polished out and ended up with lens effect right in my field of vision. It was a weird effect. Had to get a new screen.
ORIGINAL: lawrence quinn
I think they must have dwelled to long on the one patch possibly due to a really deep scratch.
Normal wiper scores should polish out with jewlers rouge. I used it where a girlfriend with a big effing diamond ring used to scratch the glass while messing with her hair (she never admitted it, but you could tell from the scratches how it happened).. I also used it when i had a wiper blade go off walkabout during rain, causing the arm to scratch the glass for about 4 strokes until I fumbled for the wiper stalk.
