Johnny C
A few days ago I went to work (about 50mins, 40 miles). When I started out the squirters were working fine as usual. After a few miles, the pressure got less and less. By the time I got to work, a measly dribble was coming out. The light wasn't on but I checked the water level anyway (i.e. I topped it up until full), still no joy.
I got home, poked them with a safety pin, then squirted water through a syringe/needle, but on both sides the water came out of the other jet, so the jets aren't blocked.
This morning they let out the measly dribble again for a few seconds and then stopped altogether
It's not the fuse, or they'd have just stopped completely.
I checked the hose going up into the bonnet, there's no kinks in it.
So it's either the tank outlet is blocked or else the motor's gone. Any ideas as to how I can check each of those options, and are there other possibilities I haven't thought of?
I don't use propietary screen wash as they dry white on the windscreen (all the motorway salt mixing in maybe) and I spend half the journey washing the smears from the last wash off,. I mix Clearalex powder with water and 10-20% meths at this time of year which leaves no residue.
How much of a job is it to replace the motor if that's gone? I'm a fairly incompetent DIY-er, and I have no garage which isn't pleasant at this time of year. Would I be best taking it into 9M?
