Windscreen Update
Bass GT3
Guy's,
Can anyone tell me if it is possible to update the 924 front screen to the later 944 flush style? If so, what parts and/or mods are required.
Regards,
Steve
Looking at the PET CD, theoretically, you could go for the flush carrera GT screen, as it seems from the sketch as if there is just an extra frame fitted to the aperture on the GT. What this would do to the angle of the wiper arms I am not sure about.
A couple of race cars have had this done, to allow 924T's to race as "GT replicas", so it's def. possible. The wipers aren't that big a problem: Use LHD late 944 arms.
I'm in two minds as to whether to get this done on my project:
Pro the wind-resistance is lessened, looks a hell of a lot better
Against The old style stiffens the chassis better, it's "original"
Its extremely straightforward. If you want to do it 'on the cheap', then you can have your existing screen removed and re-fitted on a bed of sealant and finished with a Renault 5 trim, or similar. You need to use a reasonable fitter: Ive had this done a couple of times without any problems or leaks and its cost me £45......
If you want to push the boat out then an encapsulated windscreen will cost about £200 (937 type, without the aerial) with £45 fitting on top.
Simon
