WINDSCREEN WASHER JET REMOVAL?
- Thread starter blade7
vitesse
You have to push this back with a blunt edge towards the windscreen& lift the jet moulding from the front part upwards away from the bonnet.
It will help if you warm the this section under the bonnet with a heat gun or hairdryer 1st.
Good luck??
blade7 said:Thanks, worked it out after I'd posted. Had to cut the heater wires though, as I couldn't remove the pins from the connector.
Oh dear.... you can pick up a set of those pin extractors dirt cheap from ebay / amazon.
The muppets who worked on my 944 before I recovered it cut the washer jet wires and mirror wires instead of taking them apart. Nearly caused a fire with the washer jets as they come on with the ignition, cable melted and I had to replace part of the loom, so be careful!
