Well I spent the afternoon fumbling around trying to get my windscreen washers working.
Managed to disconnect and plug the pipe to the headlamp washers so I can now fill the reservoir without it all leaking out through the headlamp washer jets.
All wiring to the reservoir pumps looks OK but when I try washing the windscreen I cannot hear the washer pump running.
I have checked the fuse and it's good.
Is there anything else electrical such as a relay I should check? - seems strange that both washer pumps should stop together.
Don't really want to have to remove the reservoir to sort things as it looks like you need to remove the headlamp motor and coil to get it out.
All help appreciated.... MoT looming on saturday.
