Advice on washer system with intensive cleaning (M286)
Here's a list of questions relating to a problem i have with the intensive cleaning fluid tank, when the washers are operated with the column stalk the fluid tank fills, all the jets are working fine, as does the intensive fluid pump when operated using dash mounted switch, so this raises the question:-
Does the washer system only use the water in main reservoir for screen cleaning
Should both the main tank pump and fluid pump operate at the same time giving a mixture at the screen
The various valves listed on the PET disc are they one way and possibly faulty thus allowing the water to enter the tank.
I've not been up the garage yet to investigate the valves but i think this is probably where my problem lies any of you guys had similar problems, i did read that the porsche cleanimg fluid can cause proplems with gumming up the system any views appreciated
Kevin
Kevin
