engleflick
My wipers don't appear to work properly;
All three speeds on the stalk work correctly, except the wipers won't park properly they just stop where ever they are when you pull the stalk into the off position.
The intermittent wipe doesn't work at all, when the switch is turned with the ignition on there is an electrical click as you would expect but the wipers do nothing. If the stalk is moved into any position whilst the intermittent switch is on the same click can be heard as the wipers do a full sweep of the screen.
I have checked all the fuses (that I can find) no problems, I have changed the wiper stalk, for a second hand one, no obvious damage to either connections wise - no change the wipers behave in exactly the same way as before.
I know that there is a relay for the intemittent wipe behind the fresh air blower, but I only really want to take the blower out again if I can be more sure that it will cure the problems (its already been out twice in the last six months to replace the blower motor!)
Im not so bothered about the intermittent not working as much as the fact the wipers won't park properly.
Any ideas - Im not sure where to look next
