Windscreen Wiper recommends
I replaced my 3.2 Carrera arms and blades with 964 arms and blades and the improvement was marked. Advice from others was to stick to Porsche OEM blades (NOT off the shelf Bosch) as these follow the 'screen contours best. My experience would support this - so I suggest OEM for your 993.
Make sure you have a stiff drink before you buy OEM ones as the set of 3 comes to about 50 quid! But... much better than the non OEM ones.
Chris ,The bosch specific fit blades which come as a pair in one box are a good fit to the screen and have the hole for the rubber buffer( which stops the blades touching each other at the end of each wiper stroke) to fit into as well.
Christian.............
