windscreen wipers
Helen Goff
No.1 Poster
just got some new windscreen wipers. but am having trouble removing the old blade units from the arms, is there a trick im missing?[:-]
They should just be standard arms with 180 degree bend on the end.
The particular style of clip holding the blades on will depend on the blades. Usually it either just pushes in or it has a little lever to release it.
You could always just break the blades off (carefully!) so you can get a better look.
sorted it was the little lever that was confusing us. and a chunk of rust that needed WD40 to help release it from the clip.
