Windscreen
Kongsodoken
Autoglass did mine and did a good job,
I believe the plastic U channel that holds the T seal is re-useable, but when they did mine the T seal did not seat perfectly so they removed the screen and replaced the U channel, however some threads seem to say that this channel comes with the screen?.....I would ask them before they arrive and make sure it is replaced
also remove all the interior trim around the window, they won't and mine was damaged luckily I had ordered new from OPC
let us us know about the U channel
Do you have the pt.no. also would like to replace the Apost covers but i,m sure i read elsewhere they are discontinued
Windscreen cracked having a new one fitted to my 944 S2 just wondering if anyone has a pair of A post covers in cobalt blue or similar i could buy also the rubber seal around the screen came out quite easy not sure though if the trim it was fixed into comes with a new screen or does it prise out thought i would do some pre med work before Autoglass turn up
Thanks Bob
