Outrun944
Hi, some simple quick questions -
1) Some ***** clipped my wing mirror at the weekend and its come loose but holding on. I presume there's a bolt that's been sheared or something ... on the inside of the wing mirror arm, what do we have that holds it onto the door frame? Is it a couple of simple bolts and nuts?
2) Reason I ask the above is I've not been able to get to see it as I'm having trouble (rather embarassingly) removing the door card. Now I've got all the screws off, all popped off around the edges, the speaker cover, the tray and arm rest ... the last bit where it seems stuck is on the door handle. Now I expected to see a screw on the door handle casing, as per instructions I found elsewhere, but no screw! I would assume then this casing pops out leaving the handle itself ... except its really frickin' tight and I've already cracked the plastic trying to carefully lever it off top and bottom
So on these '84 models ... is there a 'right' way to pop this off and door card generally?
I got a long journey tomorrow evening so freaking out trying to get this and my overheating/dead-fan problem sorted in time
3) A general wing-mirror glass question that I've been intrigued about. Both my 944's and my mates one .... seems to have convex or magnified (for want of a better word) glass on the wing mirrors - never had this before on other cars, still getting used to this - makes lane changing a little more stressful what with cars appearing 'closer' than I'm used to but especially on the N/S having blind spots when changing lanes to the left! Annoying having to adjust the mirrors down just to reverse park in the lines and all that. Is this the standard on all 944's? Has anyone changed the glass to normal or would that be a bad idea with worse blind spots? Just interested
Maybe you're all used to it by now heh!
Cheers!
Al
Cheers!
Al
