Diver944
Just thought I'd cobble together some thoughts about
common problems that rear their head at this time of
year. Most of it is common sense and I'm sure is
pretty well known anyway so apologies in advance.
1. My car won't start
If your battery is in any way suspect or getting old
(say over 4 years) then as soon as it gets cold you
will start having problems. Our cars have pretty big
pistons to turn over (especially the high compression
3 litre S2), and on a cold morning your oil is going
to be particularly thick putting even more strain on
the starter motor as it trys to spin.
Get your battery drop tested at any good accessory
shop and if it's below par, replace it with a good
brand that has a long warranty. Also consider the
newer technology calcium batteries that hold their
charge longer and are more resistant to draining
totally. Another good idea is to keep your car plugged
into a battery conditioner when it's not in use.
I use the 34.99 Carcoon conditioner from
www.carcoon.co.uk all year round. Two wires
permanently attach to the battery and there is a small
socket under the carpet in the boot to plug a long
cable into the conditioner overnight. It stops
charging as soon as the battery is back to full
strength.
2. My oil is creamy.
Another 'problem' that rears it's head in the cold and
damp is an excess of mayonnaise around the oil filler
cap and also the dipstick. Most people know that
'mayonnaise' is a sign of head gasket failure, but on
our cars it is just a symptom of the damp weather and
is in fact condensed moisture on the very long filler
neck that our cars have.
It is especially worse on a car that does short,
stop/start journeys and never gets up to full
operating temperature. My S2 has done this for the
past 6 winters that I have owned it and it generally
gets an 80 mile motorway blast a few days a week.
3. My wipers stopped working.
Another problem in the wet winter can be bearings on
the windscreen wiper armss. Open the bonnet and spray
grease on the bearing at the bottom of the wiper arm.
You will need to lift the plastic plenum covering the
passenger side one. You will see that they are
cunningly placed at the bottom of the windscreen so
that any water will gradually wash any grease away. I
do mine a few times a year after one seized and
stripped the wiper motor costing me several hundred
pounds to replace.
4. I'm getting leaks.
Finally check the 4 sunroof drains are not blocked up
with debris or autumnal leaves. There is a hole in
each corner of the sunroof gutter. Pour water down
each one and watch for 4 trickles under the car. Any
blockage can be 'gently' cleared by sliding strimmer
wire down the holes. Blockages will cause the gutter
to fill with water and then leak into the car.
The front two drains actually empty into the back
corners of the engine bay just in front of each door.
Each side has a further drain in there that also can
get blocked with leaves and will then cause leaks on
your feet when the water cannot drain away.
Nick, If you feel this could be useful I dunno if you
want to cobble any of it in to the next Porsche Post.
Anyone else got any winter 944 tips?
strength.
pounds to replace.
