The 993SS cam wasn't designed for hydraulic lifters - although I don't know if that makes any difference anyway. As I understand it, it was used in the 3.8 Cup cars (and perhaps in other applications like 964 Cup cars?). Also, a cam is a cam is a cam ! You can put most any 911 cam in any displacement 911 engine. It will change the character, just as displacement will mask the effects of a very peaky cam, for example, but it will run.
These are the technical specs:
MODEL DURATIONS .040" .050" lift C/L SETTING
964 I 246 238 .470" 113 1.26 mm
E 232 226 .430"
Super I 248 242 .490" 112 2.0 mm
Cup E 234 228 .455"
The table isn't very clear but in summary it shows that the durations are a little longer than the 964 grind cam and the lift is a little higher. It is about as "hot" a cam as you can run in a 3.2 in the two critical areas. First, valve/piston clearance and secondly, overlap in a common plenum intake engine. The theory is that it will make a little more power and also allow the engine to rev through to about 7,200rpm without the dramatic falloff in power that the SC/3.2 cam suffers after 5500rpm. So, from 5500rpm to 7000rpm it should actually make a lot more more power as the engine is able to "breath" or take in anough air to keep making power at these higher rev levels. That is the theory - yet to be proven on the dyno.
Is it designed for 3.2s? No, not really, but I don't know of any commonly available cam that is. The most common upgrade is the 964 cam but that is not a very dramatic step away from the SC/3.2 grind. The 993SS grind goes a step further. The gains are not huge as you can't use a cam like an "S" cam because of the two restrictions I noted above. Without paying for a cam to be developed, I think the 993SS cam will create the most power of any commercially available cam when used with the std Ps & Cs and intake/fuel system - I don't know of anything better anyway. I like the character of the cam so far - not peaky just a good flow of power that keeps building and building. I have only run the engine to 6500ish (due to running in) but it seems to work very well. I would guess that the midrange torque is a little down right now, but I think we can get it back with the mapping. Low restriction exhausts tend to lose midrange torque anyway, so this is not unexpected.
One engine builder basically told me I was being stupid using these cams and suggested I concentrate on the basics and get the most out of a standard engine with MOTEC mgmt to control fuel/spark. I just thought it was odd to put a "limiting" cam back in when I could put in something better and still at a later date add MOTEC if desired. Besides which, I am doing a full topend rebuild with race valve springs, Ti retainers, new rings, stretch type 993TT rod bolts and full SSI exhaust and new clutch and flywheel for, in round number, the same money as MOTEC purchase and install. That didn't add up to me.
Cheers,
Richard
