Copperman05
I intend on getting the car on a ramp and squirting a load of Dynax S50 on the front wing bottoms and sill cavities before the onset of winter. What other areas should I be looking at?
Edd
Edd
Edd to do a proper job you'd be best removing the wheelarch liners on both side, clearing out the muck and debris behind the wing bottoms and then treating with Dynax. If you just squirt the dynax in without cleaning out first, it is unlikely to do a proper job.ORIGINAL: Copperman05 I intend on getting the car on a ramp and squirting a load of Dynax S50 on the front wing bottoms and sill cavities before the onset of winter. What other areas should I be looking at? Cheers Edd
I've filled my rear wheelarch lip with grease so that water cannot collectORIGINAL: sawood12 Also check the rear lip of the wheel arch where it bends down and inwards under the car.
Seems like a good idea, thanks, how easy/difficult are the liners to take off? EddORIGINAL: Alpine Edd to do a proper job you'd be best removing the wheelarch liners on both side, clearing out the muck and debris behind the wing bottoms and then treating with Dynax. If you just squirt the dynax in without cleaning out first, it is unlikely to do a proper job.
Not that difficult, need wheels off and then there are about 5 or 6 retaining bolts to undue. You need to remove the black trim at the bottom of the wing too, that has 3 bolts from behind. The liners then pull out, with a bit of a twist and a tug. First time I did mine I think it took 45 mins per side, but i did it again earlier this year and it took about 20 mins per side. Well worth doing though; there was lots of mud at the bottom of my wings and round the black trim when I did them first time, and it is this that retains moisture and then leads to the wings rusting through from behind.ORIGINAL: Copperman05 Seems like a good idea, thanks, how easy/difficult are the liners to take off? Edd
