Winter Storage
parners
I'm new to 993 ownership and wonder if anyone can recommend how often I should get my 993 out the garage over winter, what (if anything) I should check, round the block drive or a good few miles, handbrake on or off etc etc.
Any advice would be welcomed!
to paraphrase lord flasheart in blackadder " take her out everyday and take her to even and back "[:D]
Personally I drive the car as often in winter as summer(still not enough as its a weekend car) if im taking it out, its for a drive and not just around the block, give the A/C a chance to run through, burn the condensation from the exhaust etc! I leave mine in neutral and with the handbreak off and make a point of rolling the car back and forth every time I pass it in the garage to try and help prevent discs sticking! The cars never missed a beat in10yrs and never had winter related issues. I always make sure its put away dry though just incase I dont get it out for longer than expected, helps with sticking breaks again!!!
Sorry, Pegasus already has her winter boots on and is ready for getting filthy.
I have witnessed 964s crying oil when left in the garage over winter.
So now my 'girlfriend' is no garage queen.....she's a dirty b!tch.
The other advice sounds fair enough......it's not as if there's water in the motor, that could freeze !! [:D]
Foam floor pads, tyre shoes (or putting more pressure in the tyres) will prevent flatspotting.
Battery conditioner is a must.
Enjoy,
Jon
Thanks chaps. Regs the battery conditioner, do you leave yours on permanently or just give it a blast for 24 hours every two weeks or so?
ORIGINAL: parners
If you use something like a CTEK it is best left on all the time. It manages the battery for you. My campervan gets less use than my 993 during the winter and the CTEK over last winter has restored its poorly performing battery that I was ready to replace into one that's performed as good as new since last spring.
ORIGINAL: Mark Elder
ORIGINAL: parners
+1 for the ctek
The reason, I do not drive my nice cars in winter....
http://forums.rennlist.com/rennforums/993-forum/783884-9m-mission-creep-993-lightweight-track-day-project.html
